Freeley
- Messages
- 1,672
- Vehicle
- T5 SE 174
OK this is about my T5.1 panel van not a cali but hopefully someone will have an answer for me!
The driver's electric window has gone haywire - it's 50-50 whether it will work at any given time. Sometimes it works perfectly normally but it's just as likely that it either won't work at all (sometimes accompanied by a rapid clicking noise), or even works in reverse when the window is open - if I try to close it by pulling the switch up nothing happens but if I push it down the window closes!
When I took it into my local mechanic it was working perfectly as always seems to happen so he's done nothing other than clean the contacts on the switch.
I'll be selling the van next month so want to get it sorted before I do, so was wondering if anyway has had this problem and what cured it? I'm guessing either switch or a control unit if there is one because of the randomness and reverse operation?
Sent from my Galaxy S6
