Richard16
My 2017 T6 Ocean started suffering from screen-freeze and 'touch-sensitive holes' on the screen; apparently a common problem with this generation. After a recommendation on the club forum, I took it to SatNav Systems in Surbiton (https://www.satnavsystems.com). The problem (failing Digitiser) was diagnosed & replaced within 90 minutes of arrival. Hamid also updated the SatNav map & software, confirmed the warranty & everything was explained very clearly. It's a very professional operation, highly recommended & much cheaper than a replacement system from a main VW dealer (who incidentally also use SatNav Systems).
