FaRon charger issue
Joehaugh
Oxford
T4 PopTop
Hello,
Seem to have a problem with my leisure charging system. When I plug it in to mains it will sit at around 14 Odd volts quite happily then will suddenly climb up to 15.1v and the centre console display will start flashing. I’ve seen this issue happening to people on this forum before. It’s got Gell batteries and the centre console has the correct settings. When I got access to the charger I found that the original charger has already been replaced by a FaRon unit, this was most unexpected as I was expecting to find the original charger sitting there! Anybody out there had this issue with FaRon chargers? I’m in the process of contacting them to see if they can offer any help but thought it might be worth giving a shout on here too.
Joe
mrcheesbrough
mrcheesbrough
Wiltshire
T4 PopTop
How many of those batteries do you have fitted?
mrcheesbrough
mrcheesbrough
Wiltshire
T4 PopTop
Two battery’s fitted.
Identical I take it? They’re quite low capacity for the job - VW fitted x2 80Ah or 85Ah. Not sure this would effect the charging though. You say the Central Control unit switches are set correctly - again for two batteries? What age of Westy do you have?
Joehaugh
Oxford
T4 PopTop
Yes two identical. I did think the Ah was a bit low but wouldn’t imagine that would effect the charger???!
It’s a 94 Westie
mrcheesbrough
mrcheesbrough
Wiltshire
T4 PopTop
It’s a 94 Westie
Do you know which charger is fitted? There are two, one claims to be Westfalia specific.
Cowbridge
T5 SE 180 4Motion
It’s a BLG20M12V
The Charger for the Westfalia conversions is BLG20M12V_S. The Product Code is different the _S denotes the Westfalia charger.
Could be the cause, an interaction between your charger and the Control Panel.
Joehaugh
Oxford
T4 PopTop
ok That’s interesting. If it’s just the readout in the control panel I can live with. I’ll see what my volt meter reads if I can get it to “over charge” again.
It’s sat all day with the fridge off at 13.6v. Just turned on the fridge, see what effect that has.
Joehaugh
Oxford
T4 PopTop
Thanks for your feed back today everybody
ArcticMatt
ArcticMatt
Beiarn, Norway
T4 Hightop
The case might be the same for both. Mine doesnt have the "_S" on the case but it is the westfalia compatible version. Does yours have the little blue wire on the other side of the charger connected to a 6-pin plug (to the control unit)?
IMG_20171219_132527 by Matt Wilde, on Flickr
ArcticMatt
ArcticMatt
Beiarn, Norway
T4 Hightop
Hello,
Joe
Is that top switch just hidden by the fuse holder set to "Battery Charger" and not supply
Joehaugh
Oxford
T4 PopTop
Hi, yes it does have the blue wire going in to the multi plug.
Regards
Joe
ArcticMatt
ArcticMatt
Beiarn, Norway
T4 Hightop
Seems legit. Hopefully it's not the westy controller that's the issue. Your voltmeter readings were ok you said? Does it happen every time the charger is on?
Sent from my ONEPLUS A5000 using Tapatalk
Joehaugh
Oxford
T4 PopTop
Yes the Westie controller and my volt meter give the same reading. I does not happen every time, some times it’s fine for a day
ArcticMatt
ArcticMatt
Beiarn, Norway
T4 Hightop
Maybe email FraRon and see if they can help perhaps?
ArcticMatt
ArcticMatt
Beiarn, Norway
T4 Hightop
Seems like a similar issue here
HTML
