Fault display on electric control panel
N
nick100
Devon
T6 Ocean 204 4Motion
Hi there, we have a 19m old T6, and had a 2x100W T6 kit with victron MPPT installed a year ago by Roger Donoghue in Taunton.
Today we noticed that the icon bottom right of the control panel, which usually tells you if you are plugged in to the external power source was displaying a flashing icon, consisting of an alternating plug symbol with the letter G.
The manual informed me that this is possibly an overcharged battery, to disconnect from the external power ( we were not connected, and haven't needed to since the panels were installed), and contact a dealership immediately.
However I thought I might get less sucking of teeth and more sense here, so I am asking for some help and advice.
Many thanks,
Nick.
Try pressing the bottom RHS button for 30secs to reset any errors to start with.
Many thanks,
Nick.
Check Control Panel Diagnostics.
Control Panel Off and wait 30 secs
Control Panel On
Press and Hold R lower button and then press Control Knob for 5 secs.
New Hidden Menu . Scroll to VW Diagnostics.
If there are any codes shown, take note and then Reset/Clear.
Return to Main Menu.
Switch Off Control Panel using L lower button. Wait 30 secs and Switch On.
Any problems should be resolved assuming these are Electronic and not Mechanical.
Error Codes from Control Panel.
1 = 1 = Pop-up roof
2 = 2 = Plumbing Heating
3 = 3 = Cool box Cooler
4 = 4 = Sewage wastewater
5 = 5 = Fresh water
6 = 6 = Outside temperature
7 = 7 = Battery
Error Code Defect Fault
10 1010 Short-circuit to (earth) roof
1001 1001 Fuse / short circuit to (plus+) roof
1100 1100 Short-circuit output Roof "on"
1101 1101 Fuse roof "to"
1110 1110 Short-circuit output Roof "to"
1111 1111 Fuse starting Roof "to"
2100 2100 Short-circuit output heating on / off
2101 2101 Fuse output heating on / off
2001 2001 Interrupt input heating 30
3100 3100 Short-circuit output coolbox
3101 3101 Fuse interrupt output coolbox
3001 3001-J698-cooler input error "Active"
3010 3010 Short-circuit input icebox "actual temperature"
3011 3011 Interrupt or fuse input icebox "actual temperature"
4000 4000 Short-circuit to ground water level sensor
4001 4001 Fuse circuit to plus water level sensor failure
5000 5000 Short-circuit to ground water level sensor
5001 5001 Short circuit to plus water level sensor failure
6000 6000 Short-circuit to ground temperature sensor or for outdoor temperature
6001 6001 Fuse / short circuit to plus two temperature sensors for outside temperature
7001 7001 interrupt input interrupt input D +
Control Panel On
1 = 1 = Pop-up roof
5 = 5 = Fresh water
7 = 7 = Battery
Many thanks for this information. I will give this a go this morning.
This proved very useful to me.
I wasn't aware of the hidden menu, and this allowed me to tell my T5 that I didn't have a hydraulic roof anymore (Dumé's conversion).
It also reset the battery charging error.
