Caliman300
HiMy fridge in my 2012 cali has always been a little temperamental. I can always get it to work by adjusting the main control panel settings but it sometimes allows everything inside the fridge to warm up before chilling again. I feel the problem is more to do with the main California roof mounted panel rather than the Danfoss controller. Does anyone know;
How the California panel interfaces with the Danfoss controller?
Is the panel the thermostat/ main controller and has ultimate control over the fridge. If this is the case the temperature probe must connect to the panel and open and close a no volt contact that would connect across the thermostat connections on the Danfoss.
Our Cali (late 2011) has recently started doing exactly what you describe it gets to warm befor starting to chill again. Did you fix this if so how.
