V
vbk1975
Yes, I think it is the switching box that is likely the issueThank you!
So does that mean you believe the sensor is working ok?
Maybe the problem could be with this module:
I’m not sure what it is or does?
Thanks again for your help
So from what I can determine it is a switching box (Transistors and resistors) that not only switches the Fridge controller on (Red wire from Van side) it also switches in a resistor between C & T that sets the fan speed (I think) and it has some other resistors in there that I think set the voltage thresholds for operation. I would open it carefully and see if it has a dry joint.
The first vans just had a standard relay in the place of this. Relay driven by the 12v from the Control Panel, earth to body and then the relay connected T to P&C (Spliced together) when the relay was switched on
