Eber123
Hello,
I used the nice weather to do some work on the camper. There were a few things I wanted to "improve", at least it was the idea. We will use those changes for a while and if they are good we leave it, if not we change it back.
I did my best to ensure that the camper can be brought back in the original state. Have I said that there are 2x exceptions which I will point out later. Of course I bought parts from companies which I will mention as well, but that doesn't mean I want to advertise for them.
Let's start with two pictures of the camper as it is at the moment:
In a different post I mentioned the additional storage space. I just wanted to use this post also to add some pictures. It is installed for a week or so and works well. Let's see if the installation will survive the camper lifestyle:
Here is a picture just from the front. The door is locked with 2x VW push buttons and a magnet:
I specifically put the a 10 cm high board in front of the shelve which should work as another barrier.
This extra storage suppose to be for food. At the moment I believe it is big enough.
Here is a picture from the back. The door to the fuse cabinet does still fully open:
I wanted to close the gap beside the new storage cabinet, which was possible because I had a wee bit of timber left (ok it doesn't look to well from the boot, but it is ok from the living area:
I wanted to use the space under the outside shower for storage. My aim was to create this with things I can find in the garage I didn't want to go ahead and spend more many. In the boxes we store shoes, rainjackets etc.
I used the airline stripe to fix a iron rod which hold the two boxes:
I believe I may only attache 10x pictures. So I will post this and will continue on a second entry in this post.
Eberhard
Eberhard
