E
Elrao
Did the folding mirror tweak this morning, was bothering me that they didn't fold as it is the easiest way to see if the vehicle is locked! Took longer to update VCDS on my laptop than make the changes, very easy (following instructions from a How To video on You Tube).
09 Central Electronics --> Adaptations (having enabled) --> Channel (58) --> by_lock_command_remote_key
The only downside is that they only unfold when you put the key in the ignition, so it actually doesn't tell me if it is is locked or not (just that i have locked it since I turned it off). Is there a way to have them un-fold on unlocking (rather than ignition)?
Am guessing this would be another channel, that might need a value like by_unlock_command_remote_key
