Welcome on your first post .
There are treads on solarpanels and DIY solarpanels ...."search" might give some info
The thin flexi ones are less popular i think due the higher price.
I have recently fitted 200 watts of panels to my van. Easy to do, and they bolt onto the roof rails.Hi I'm new to all this, a quick question for you all has anyone fitted a solar panel to there van?? Thanks again Ben
Where did you get them from??I have recently fitted 200 watts of panels to my van. Easy to do, and they bolt onto the roof rails.
Not cheap, but I hope never to have to hookup again, and they should prolong the battery life.
Sounds good could you point me to his website??I have a flexi panel on my old van, they are very good and a little more expensive than the thicker versions but much lower profile. I think Roger's setup uses the thinner flexi panel with some custom made brackets to avoid the need for bonding?
I much prefer the lower profile ones to the thick framed ones personally, less drag, noise and less noticeable.
solarcampersolutions.co.ukWhere did you get them from??
