Fog Light Bulbs - Changing
United Kingdom
T5 SE 180 4Motion
I've got some Nightbreaker bulbs for the fog lights. I've read the handbook - but for the life of me I cannot get the trim off to get to the fog light and the 3 screws and I don't want to break anything. How do you get the trim off, is there a trick to it?
Any advice much appreciated.
Just grip inside the circular bit and pull sideways a little they are tight to start with
Absolutely right Kev, it'll make some scary cracking noises along the way that you would never want to hear from your pride and joy... but that's the way.
Hi both, I'm not sure what you mean by " Grip inside the circular bit ". Do you mean a finger inside the hole just above the foglight?
How is the panel secured?
Yes I mean the recessed bit. it is held in with lugs. it is robust so shouldn't break
Ok. I'll give it a go tomorrow.
Thank you Calikev. Very helpful. Thank you.
All done between the Hailstone showers. An awful lot of force required, but thanks for all the advice and pictures.:thumb
