![Bigted](/data/avatars/m/9/9957.jpg?1436435860)
Bigted
VIP Trade Partner
- Messages
- 562
- Vehicle
- T5 Beach
Thank you for that, I've just ordered
I put my on the multiplex board. I use a strap to hold it down. Worked well on a 2,000 mile French trip in OctoberAnyone with thoughts or experience of mounting a fridge to the top of the multiflex?
Idea is to have a Waeco CFX35 or alternative on the multiflex with Slidepod below.
Will move the fridge to behind the front seats when we camp (and leave the 2 additional seats at home).
Thanks but we have a 3 seat bench (and 2 additional single seats). Current thought is to go for a Waeco CFX28 because a "quick release" mounting plate is available which I could fix to the top of the multiflex. The plate should be ok under the mattress when we remove the fridge to sleep.Fitted ours at the side:
I'd be happy to strap down using the handles but for the fact that it would restrict the location and orientation of the fridgeI have a CFC 28 - seems a good fridge but still quite new for definite verdict. I keep it strapped down via it's handles behind the front seats. I would be tempted to strap it down rather that the plate to avoid the bump in the bed if on the multiflex. The handles are very strong and it's going nowhere when strapped down.
Can now confirm after several uses that you can't tell that the mounting plate is under the mattress when sleepingView attachment 18080
Waeco CFX 28 on quick-release mounting plate CFX-QFK.
Perfect size for 3 seat multiflex as can be used in either position.
Don't envisage problem when sleeping as plate is low profile (max 26mm) so should sit OK under mattress
I got a CFX28 the other day, brilliant fridge. Cant believe how quickly it dropped from +17 to -5Can now confirm after several uses that you can't tell that the mounting plate is under the mattress when sleeping
