Fridge no cooling fan going and control panel working
F
francoisb77
Nelson
T4 PopTop
Hello,
I have a T4 Westfalia full camper 1992. I am having an issue with the fridge, it not getting cold . The control panel works great with the snow flake and temp can be changed , Battery is 14.2 amps, the fan is going for a bit but then I hear a beep (it then stop for a few second and fan goes again). I am wondering if I simply need to add refrigerant? I am assuming the electric unit is working fine since the fan starts?
Any insight would be great.
Thank you
Tons of threads on here on this subject. Search is your friend.
Could be 1 of 2 things. Either the control box that sits next to the compressor under the fridge or the refrigerant needs recharging.
For the first , there are simple diagnostic tests, again it’s all on here in other threads.
For the second you’ll need to remove the fridge unit and take it to these guys.
On their website you’ll find instructions on how to test the control box.
Shout if you need more help.
