P
pjor
Hoping someone might be able to offer some help with the following:
I have a 2008 T5 Cali and recently the fridge went on the blink.
Basically, when I switch fridge on at control unit, light comes on and I hear it switch on but straightaway it switches itself off and light goes off.
I have taken it to a local mechanic who does conversions and he was able to hook up a laptop with VW software and brought up the following 2 faults:
Refrigerator pressure too low (does this suggest compressor issue?)
Air pressure sensor fault
He's pretty busy at the moment and can't investigate further for at least a month (and he didn't seem over keen - doesn't do much work on Calis and didn't have any immediate quick fix)
Have been reading through the many threads relating to topic of fridge faults and have done following:
Checked fuse under passenger seat - fine
Checked diagnostics on control unit - only shows fault code 5001 - issue with water tank sensor which I already knew about.
Control unit shows leisure battery charge at 12.7 V and van hasn't been driven for a week (50% charge showing) - does this suggest unlikely to be fault with leisure battery?
Is next step to try to remove the Danfoss controller? If so, any advice on how best to do this would be much appreciated.
Or is there something else I should be doing before removing controller?
