D
DebsWhite
- Messages
- 76
Can anyone tell me whether the Waeco CF 25 will fit between the two front seats in the Beach? It's looking pretty tight to me, but wondered if anyone had the definitive answer?
hi,
The biggest compressor fridge that fits between the front seats is the Isotherm TB-18.
It's a great little fridge we have one and fits perfectly.
http://www.indelwebastomarine.com/int/products/fridges-freezers/travel-boxes/travel-box-tb-18/
Hi cleve..I put a few pics of the CF25 and CF18 together when we tried them for size in our beach. Pics in this thread if that's helpful.
http://vwcaliforniaclub.com/threads/blackberry-beach-ordered-today-need-fridge-advice.6833/
We went for the CF25 and glad that we didn't get anything smaller. We do find it carries the essentials but we have to shop every couple of days to keep stocked as we can't carry as much as we'd like but it's worth the compromise and a good excuse to shop fresh and local. We had a bigger 40L 12v cooler initially which was a great capacity but just so cumbersome and took up too much space.
The location of the cf25 behind the handbrake, next to our pod works well as we can access it enroute to throw snacks to the children or get a cold drink out, still climb over it to get in the back and it doesn't get in the way or need moving when the lower bed is out.
We don't secure the waeco at all. We found as long as it sits between the rails it doesn't slide about on the floor. We keep ours alongside the pod in line with the handbrake. If we rotate it 90 degrees it does slide about because of the slight raised level of the seat rails. If we have had it in this position (e..g when additional captains seat fitted) we just put some of the non slip matting underneath and that seems to work.Hi cleve..
Great information. Just wondering how you secure the CF25? I may go for this or the CF18..
Many thanks Cleve...We don't secure the waeco at all. We found as long as it sits between the rails it doesn't slide about on the floor. We keep ours alongside the pod in line with the handbrake. If we rotate it 90 degrees it does slide about because of the slight raised level of the seat rails. If we have had it in this position (e..g when additional captains seat fitted) we just put some of the non slip matting underneath and that seems to work.
Personally I wouldn't go any smaller than the CF 25 as we can get essentials in and enough for about 2 meals at a stretch but that's it. We feel we have to shop pretty regularly and do things like anticipate what we will use and count out tomatoes into a little sandwich bag so we don't pack more than we need!!
Hi Tim.. in the forum beach fridge username joseph. Joseph posted a photo of his waeco cdf 11 between the front seats. I think I'm correct with this?!Can anyone tell me what is the largest capacity compressor fridge that will physically fit between the two front seats - its seems the TB18 at 23.5cm wide is the best option with 18lt capacity. Can anyone confirm if the Waeco CDF25 at 26cm will squeeze in the gap ?. Thanks
CF25 won't fit with the handbrake unfortunately.Can anyone tell me what is the largest capacity compressor fridge that will physically fit between the two front seats - its seems the TB18 at 23.5cm wide is the best option with 18lt capacity. Can anyone confirm if the Waeco CDF25 at 26cm will squeeze in the gap ?. Thanks
I may be wrong but think the VW one is just a 12v cooler not a compressor fridge so will rapidly drain your battery in which case you may as well go for a cheaper one from halfords or simlar! It can be secured into the rails too I think.Anything wrong with the vw own cool/warm box that is on the optional extras? Can it be fasten down or is it free standing? Seems like waeco are favoured by most!
CF 18 looks interesting but does it run off 240 when on hookup. Looks from the pics as though it only has one lead, i.e. only 12v????
We are still very happy with our cheapo lidl coolbox which fits in the Beach 2 seated between the side storage box and the front seat. We have the multiplex board at the back and the box as far to the back of the van as possible and then the coolbox is held neatly in place by the front lip of the storage box if you see what I mean.
Whenever we're on a site on hookup we have it outside so you don't hear the fan, either under the awning or in the drive away awning. If we aren't on hookup then we'll just turn it off for the night. Seems to keep things cool enough like this.
