P
PeterMVR
- Messages
- 5
Hi,
Has anyone had problems with the electric engaging motor on the otherwise manual sliding door? Mine has malfunctioned and hense, although the door will slide shut and is lockable, it dosnt engage properly leaving a visible gap to the outside. I've checked all the fuses in both the lower dashboard area and under the passenger seat (none visable under the driver seat) without any luck. That said the manual seems to indicate a fuse for the sliding door in the under passenger seat array but i couldnt locate this particular fuse. Might anyone know where the fuse for the door motor is exactly? Any other suggestions or advice would of course be much appreciated.
Many thanks,
Peter
Many thanks,
Peter
