Hi there, if it’s not being used you really need to plug it in to charge all batteries as firstly it charges the leisure battery first then the starter battery. Once they are both charged it will maintain them both.Hi there.
Just receive our GC600 3 weeks ago.
We have been starting the van every week and charging the battery. Started it today after 6 days and says the battery is flat with isolator in the off position.
Common issuewith no solar power ?
Hi Alison.When you say starting the van - have you been driving at all?
Have you used electric hook up to charge the leisure batteries?
I’d recommend something like a CTEK charger. A normal charge cable is fine if the battery has never been depleted. But a CTEK (or other make) can recondition IF the battery is not destroyed. Maybe borrow one in the first instance?Hi Alison.
Yeah we have driven 50 miles each time and battery reading is 100% but within a few days it is at 0%. Yeah ill need to buy the charging hook up lead and try a night on the mains charger
Maybe it’s because I’m not from Aberdeenshire!Hi there.
Mine to no issues, also bar heater and dehumidifierMine’s been on permanent hook up since December. Leisure battery perfect and starter fires perfectly for the weekly shake down loop.
Be careful. I’m “City” not “Shire” as I learnt early on as an English person relocating from Norway. The lady from the council put me in my place very quickly.Maybe it’s because I’m not from Aberdeenshire!
Ha got that Alison, my 600 hung around at the port on the first lockdown for 3.5 months and took this up with the dealer but no fault found and to date all fine but gets plugged in if standing any more than 2 weeks.Be careful. I’m “City” not “Shire” as I learnt early on as an English person relocating from Norway. The lady from the council put me in my place very quickly.
But, back to the task at hand...
I wonder if the battery is draining from something being connected? Or was it already drained on delivery?
It seems there are a few GC threads on the same issue (hopefully not all from Aberdeen(shire))..
Frustrating for you. I’d use a CTEK as well to see if that can help recondition it.Ha got that Alison, my 600 hung around at the port on the first lockdown for 3.5 months and took this up with the dealer but no fault found and to date all fine but gets plugged in if standing any more than 2 weeks.
Not a CTEK but I got this an my experience is not good.Frustrating for you. I’d use a CTEK as well to see if that can help recondition it.
Translated:Hola
Es muy importante que vigiles muy bien ese consumo.
yo estrené una GC 600 y observe por las noches muchos ruidos Tipo reales.
Y eso que hacía pruebas como tener la nevera desconectada,agua y calefaccion en of y seguía igual.Si el vehículos no se usaba en 4 días..... ya ni arrancaba.
Vehiculo en taller y ...... después de 45 días de pruebas y más pruebas..... se decide por parte de concesionario suministrarme otra,ahora después de 5 meses largos de espera, por fin feliz en la nueva GC 600.
Los consumos no son ninguna broma , te recomiendo que documentes todo lo que te ocurra.
