T20 Torx screws along the top edge viewed with the lid open, similar along the bottom edge looking up from the floor.
Then remove the dash end panel, plastic trim tools are the best things to use for this. This panel has to come off as there is a plastic part that locks the glove box in place. If you remove the wiring plug from the airbag deactivation switch DON'T SWITCH THE IGNITION ON WITH IT REMOVED as this will bring on an airbag fail warning which cannot be reset without using in a diagnostic tool.
The glove box should than swing down and be removable.
Be careful not to let the door close if you only let the dash end panel hang on the wiring as it gets crushed between the door and the dash end.
Be careful of the very sharp edges of the metal work hidden behind this area.
Hope this helps.
Rod
