glow plug light and Emissions light
Actionwave
Actionwave
Novice California Owner
bexley, kent
T5 SE 180 4Motion
I'm posting this again as originally posted in. Wrong section
Just driving my van and the glow plug lights started flashing and then 10 mins later the emissions light came on. then a fault with Auto start stop!!!!!
Help
Flashing glowplug is fault identified by the engine ecu so can a faulty sensor or issue, but multiple faults can be wiring like an earth fault where a number of sensors all use the same ground point.
There are also fuses in fuse box B(next to starter battery) that supply power to a number of sensors, could be worth a cursory look to check for blown or unseated fuses.
Just dropped into Beadles Dartford, quite impressed told not to drive it and took it in straight away.
Fingers crossed just something simple.........
told it is the Exhaust gas sensor £300.00, hope they are right..........
If this is a t4 the brake light bulb can bring one the pigtail light also the brake light switch so if it is a t4? Check them things this is common on t4s
