Billywizz
You can get them on eBay, 10pcs X Genuine Volkswagen VW Panel Fixing Clips Carpet in Black For VW T4 T5 T6Where do you get them from please?
Hi yes they are available from vw and they are easy to replace you can normally screw in a 3.5mm self tapping screw into the middle of the old stud and wiggle it out with a pair of pliers. If you put your roof about three quarters of the way up there is enough movement in the bellows to achieve this.
Hi mateHello VW Guru! SO glad I found this thread conversation, even if it goes back a few years. We've just bought a T6 Cali and six of these plastic washers are either broken off or missing. One side of the headlining very floppy indeed. Have looked on TPS and on Cali Club shop but to no avail so I'm wondering if you are you able to sell me some of these washers?
Hope so!
Ta!
Stu
I’m assuming you mean the two piece rivet clips?Hi mate
Don’t use the ones VW try to secure the lining up with, you will always have the same problem. Get these from your local VW dealer or eBay....10pcs X Genuine Volkswagen VW Panel Fixing Clips Carpet in Black For VW T4 T5 T6
Yes we could supply you with the correct clip or the other rivet clip I think @Billywizz is on about or I could give you the part numbers so you can source them locallyHello VW Guru! SO glad I found this thread conversation, even if it goes back a few years. We've just bought a T6 Cali and six of these plastic washers are either broken off or missing. One side of the headlining very floppy indeed. Have looked on TPS and on Cali Club shop but to no avail so I'm wondering if you are you able to sell me some of these washers?
Hope so!
Ta!
Stu
Yes they worked well for meI’m assuming you mean the two piece rivet clips?
I got these from Southern motor group Cowfold,they ordered them within 2 days,I hope they lastWish I'd just bought the clips off eBay. Apparently my dealer only has 1 in stock and I need 6. They need to order more from Germany.
Waste of time and fuel taking my Cali in. I now have to collect it and return again when the clips arrive.
Sent from my Moto G (5) Plus using Tapatalk
I can only find them on eBay 10 for £10, can you supply the link or a picture so I can locate themTwo part light grey vw panel clips from eBay, UK seller, couple of day delivery, £2.19 for 10nr .
Perfect fit and very secure, only replaced four missing ones for now, but I now have the spares for when ( not if ) the others fall out.
Thanks for the tip Billwhiz
Why keep going back?, surely you you just buy the replacement rivets and replace as necessary and save yourself the visit?Bad design these, ive been back in three times with these coming off![]()
They got done on each service (2) and another time when I got suspension done. It’s still a pain in the d£&k to manage so the kids don’t swing on it but point noted, I’ll be ordering those rivets when they snap again. And they will I’m sure.Why keep going back?, surely you you just buy the replacement rivets and replace as necessary and save yourself the visit?
Billy Whizz should be credited with the fix, but thank you for your acknowledgmentJust fixed our coming-away ceiling with advice and clips recommended by Perfectos & BillyWhizz, thank you. Just copying this in from another thread as it's more relevant here.
It was good advice to have the roof not quite fully up so that the bellows allow some movement, as the holes are awkward to get at. Putting the new clips/plugs in requires some pressure at an awkward angle, but we managed to do it with a smart tap with a hammer from outside the bellows (carefully).
It is a bit fiddly, but the idea that VW feel the need to take off the bellows to do the work is ludicrous - perfectly possible to fix it without.
