MurrayR
- Messages
- 51
Our 07 Cali has a fault with the grey water tank level sensor. The indicator shows one bar even though the tank is full to overflowing. Can the sensor be repaired or does it require replacement?
The waste tank has an Air vent that acts as an overflow if the tank fill to maximum. So you don't really need any further indication. Once full , if not emptied, it will just overflow.I've noticed the same and thought it was fault - three days of washing up water and no bars on the waste tank indicator.
An indicator lamp near the sink and water tap that came on when the tank was nearly full would be more useful.
With the existing system and no advance warning, if you are busy running the tap and not looking at the control panel, it could easily overflow (where would the water go???).
I am going to put one or two lots of 15 litres into the water tank at a time with a jerry can in future, so I know when the waste tank is likely to be full.
Basically the Waste Water Indicator shows Full or Empty, nothing in between.Hi all. The Grey water tank is not registering as full on central control unit on our 2019 Ocean, has anyone else experienced similar?
I also couldn’t unscrew the fresh water tank (inside the cupboard) seems like it may have been overtightened at the factory; any tips on how I can get it off?
Thank you WelshGas! Really appreciate your quick and comprehensive reply.Basically the Waste Water Indicator shows Full or Empty, nothing in between.
How do you know it is full.
Waste Water tank Cap/Hatch needs to be tight.
You need a special tool to get it off.
Or make your own. Also available from Forum Shop.
According to this drawing what is the waterThe waste tank has an Air vent that acts as an overflow if the tank fill to maximum. So you don't really need any further indication. Once full , if not emptied, it will just overflow.
See Parts 12,7 etc:
Part 3 is the Grey water sensor.According to this drawing what is the water
sensor ?
Sent from my SM-A920F using Tapatalk
So I be more specific looking for the waste water sensor on a t5 2007. CheersAccording to this drawing what is the water
sensor ?
