D
Delfhill
I know this has been discussed in the past, but I would greatly appreciate the answer to one simple question. I used to regularly change the Haldex oil and filter on my T5 but as you know there is no filter on the T6, just a strainer on the pump itself. It seems inevitable that this will eventually clog up, which has happened on our Tiguan 4Motion causing the control module to overload and fail. Whilst waiting several weeks for a new module, fortunately under warranty, I removed the pump and cleaned the blocked strainer, a very easy quick task. Now I am worried about our 4Motion Cali, should I clean the strainer? There are numerous YouTube videos and forum discussions about this, roughly half say just clean the strainer and refill with oil, the others say it is vital to plug into a VAG computer to relearn the pump. I have no access to such a computer and my local van centre are not interested in doing the job, so my question is this: do I really need to go through the pump relearning procedure or can I just clean the strainer and add new oil? Very many thanks in anticipation.
I have attached a photo of the Tiguan’s strainer, an identical Haldex unit.
