We don't adjust and we are not flashed. The LED's are almost entirely level when dipped with no LH slope up.Hi I’m going to Spain in our t6.1 California. I can’t see a definitive thread about whether I need to adjust my LED lights. Any advice would be very welcomed.
LED lights have a flat beam pattern. No adjustments necessary.Hi I’m going to Spain in our t6.1 California. I can’t see a definitive thread about whether I need to adjust my LED lights. Any advice would be very welcomed.
That is for adjusting your headlights when going abroad - you have a T6, the T6.1 has different lights & no travel adjustment.I have LED headlights on my LHD Ocean, in the settings on the computer it has Travel Mode, is this not to do with headlights or is it for the radar on the ACC? So it knows which way cars are placed when it slows you down?
They are not quite totally flat & the lenses are different for LHD vans as someone found out when trying to import or export a van, I cant remember which way round it was.They give a totally flat beam.
I agree nearly flat but not quite.They are not quite totally flat & the lenses are different for LHD vans as someone found out when trying to import or export a van, I cant remember which way round it was.
I recall it being a UK van exported to Switzerland.They are not quite totally flat & the lenses are different for LHD vans as someone found out when trying to import or export a van, I cant remember which way round it was.
I asked this question when we first went to France in our Ocean 6.1. I'm told that the vehicle knows where it is via the sat nav and the led headlights adapt to the other side of the road. I have never been flashed.We don't adjust and we are not flashed. The LED's are almost entirely level when dipped with no LH slope up.
Other than the basic levelling motors there are no moving parts within the headlights, so I can’t see that happening.I asked this question when we first went to France in our Ocean 6.1. I'm told that the vehicle knows where it is via the sat nav and the led headlights adapt to the other side of the road. I have never been flashed.
We were told by our VW dealer that there is no need to adjust the LED lights. To date when we’ve traveled on the continent we haven’t had an issueHi I’m going to Spain in our t6.1 California. I can’t see a definitive thread about whether I need to adjust my LED lights. Any advice would be very welcomed.
The lamps have certification markings on them that dictate if they have been designed and certified for use on both road sides. Generally it is the offside lamp that will be the one that is marked for both sides of road. The lamps that are certified for use on both sides, still have a prominent side and are still optimised for hand of drive. So they are meant for occasional use but won’t be accepted for permanent export.Accepting that there appears to be no physical need to apply those nasty stick-on adapters to 6.1 headlights, how would the discussion go if / when I am stopped by a gun toting traffic cop in say Germany? Is there anything documented to support our theory that they are not required?
