martynradmore
- Messages
- 2
I used to smear vaseline on the lens before attaching eurolites. They stick well but peel off easily when needed.
Instructions are in the pack.Brilliant, thanks. Have ordered some Eurolites. If anyone has a diagram of where they should be positioned, that would be very useful!
I've bought removable headlight protectors in acrylic that have the European stickers attached. The protectors are attached by a single screw and clip that fixes to the middle top of each headlight unit. Does require drilling a small hole to take the clip screw, but once in place the clip stays there. They take seconds to fix and protect your headlights from stones chipsHi all - I have seen a few posts on this subject, but haven't managed to find a definitive answer!!
I am off to France on Friday and was wondering if I needed headlight deflectors....
I have a 2014 SE 140 BMT - there appears to be some kind of headlight adjuster on the dash, but not sure if this is sufficient?
I am reluctant to put 'Eurolites' stickers on as they are a b****r to remove.
Has anyone any advice?
Very much appreciated.
TTP
Bristol
