Exactly I wasnt able to get it ticking very slowly which is a fuel pump I suppose. So WG stating it doesnt have variable power output is wrong. It might not have a direct control over that setting though. A slightly warm air out of the want goes only in case of cool down when pump already stopped. So to clarify the ticking, does it go slower than around each second tick? Thats the slowest ive heard from it.
Maybe I haven't explained it properly. The Burner burn's the diesel to give a
set temperature in the heat exchanger,
this is NOT controllable by the Control Panel, which is cooled by the air flowing over the heat exchanger which is propelled by the fan. The fan speed, hence amount of air, is controlled by the thermostat/temperature sensor that is within the air intake assembly.
Cold car - high fan speed - heat exchanger cooled - more diesel burnt to maintain heat exchanger temperature - faster fuel pump speed/tick.
The speed of the fuel pump is not controlled directly by the control panel to produce a higher temperature in the heat exchanger but by the cooling air flow through the heat exchanger which is determined by the Temperature selected which controls the fan speed and the overriding thermostat control which slows the fan/air flow down as you reach the selected temperature within the vehicle. When you reach the selected temperature the fan speed is low - the air flow is low - the heat exchanger is not cooled so much - the burner/fuel pump backs off as it is easier to maintain the temperature in the heat exchanger.
In another comparison - an electric shower. The temperature controller doesn't control the electric power to the heating element thats On at 10Kw. The temperature controller controls the flow of water over the heating element. Hot shower - low water flow, cool shower - high water flow.
Back to the Van. If the heater does not stay on continuously heating all night then maybe it is set too high. It switches off because when upto temperature and the air fan is at it's lowest speed setting, controlled by the thermostat, the temperature still rises within the van so the heater switches off into standby and will restart if and when the temperature falls below the selected temperature.
Or the airflow through the heat exchanger is obstructed, air inlet/outlet obstructed or fan defective so that the heat exchanger cannot be cooled effectively so heater switches off.
I find that Temperature Level 1 or 2 is more than adequate overnight.
This is on the T5 SE. They may have changed something on the T6 and the Beach may be different to the Ocean. Check that the air inlet/outlet for the heater is not obstructed in any way.
