Heater Problem
ceegee
ceegee
T5 SE 174
I have got the Cali out to take away and when I hit the heater switch it does nothing and the "wiggly lines" symbol on the display just flashes.
If I go to the heater section of the control panel, it does nothing if I hit either the "on" or "off" options.
I've been trying it while it is on hook-up.
Any ideas ??
Various possibilities. Any fault code (2101?) in diagnostics?
Flashing symbol means an error , first always reset the controlpanel and see if it helps
I don't have a fault code reader :/
How do I reset the control panel ?
Press and hold dial button together with lower right button. Then go into diagnostics. Note number down then press and hold lower right button to clear.
Great, thanks - I'll try first thing in the morning :)
Okay, did the reset and all is well.
Thanks for the help :thumb
Tunworththunderbolt
Hotel California
H
Victor_Tango_
T6 CFO
T6 CFO
Emil Silenhag
Emil Silenhag
