CharliFornia
CharliFornia
- Messages
- 29
- Vehicle
- T5 SE 180 4Motion
I was going to try aluminium sticky tape, but will take it away from the ‘manufactured’ look I was aiming for.Great idea!
Perhaps a heat resistant lining or ideally coating may help. I’ve seen of similar thoughts on the forum - this has promise. Perhaps V2 could have thin metal sliding clips behind the original heat vent housing and a hook next to the jubilee clip at the base hanging enough weight to keep it in place counterbalancing the effect of the blower
I was also considering holes to allow some heat into the bottom half of the van.I think other attempts have left some of the air blowing into the lower bed area. I can't see if yours does that, or if you'd consider that desirable.
There is another vent at the rear of the sliding door. But the most heat comes from the B-pillar vent.I was also considering holes to allow some heat into the bottom half of the van.
Something for version 2. I wanted to prove the concept first. But all moot if the plastic goes as soft as cheese when on.
That vent by the rear chair is the heating when driving.There is another vent at the rear of the sliding door. But the most heat comes from the B-pillar vent.
My bad. I think you are rightThat vent by the rear chair is the heating when driving.
However there is another smaller vent for the aux heater on the B pillar.
I was banking on this one putting out enough heat to keep downstairs happy.
It’s all fun.
We now use this smaller B-pillar vent to 'tap' for upstairs, leaving the other for the downstairs section.However there is another smaller vent for the aux heater on the B pillar.
Excellent idea. I’ll look into that. Thank you.A thought no more
Could you use liquid plastic to coat and strengthen your creation?
https://www.ecopoxy.com/liquid-plastic/
It does but the Roof Bellows leeches the heat away and with the upper bed down there is a relatively small entry into the upper berth right at the highest point and where the ventilation grills are so the heat doesn’t get to the rear of the upper compartment.Doesn't hot air rise?
Variation on a theme. 3D designed attachment to divert the heat upstairs.
Still very much in the prototype stage.
Problem 1: the PLA used for 3D printing is not suitable for end product as it goes very soft in the heat of the blower.
But... it works.
View attachment 45089View attachment 45090View attachment 45091View attachment 45092View attachment 45093View attachment 45094
Hello,Any progress report on this?
It looks great!
