Hella Socket - anyone using...
I've got a csl 12v USB charger, it's not Hella though just normal I think in my beach
There isn't a Hella socket in the California, neither of those will fit. (EDIT: *current* California)
You can use a standard cigar lighter USB charger (I choose Anker) but I wouldn't leave it in permanently as you may drain the leisure battery in time.
Previous version had hella sockets next to the 250v socket. Oceans have a standard cigarette type socket.
They fitted hella sockets to pre 2009 calis instead of the 12v cigarette ones now
Yep 2008 calli -
so can it be safely used when running off hookup and also off leisure battery?
Also if you leave one of those plugged in would drain the battery?
Is any one using one of these in the socket behind the passenger seat - https://www.amazon.co.uk/gp/product/B00QR70IAC/?tag=eliteelect-21
or
https://www.amazon.co.uk/gp/product/B00AU0OA9C/?tag=eliteelect-21
If so can it safely be used when running off hookup and also off grid?
Should work fine, BUT do not leave plugged in when not in use as will still consume power and can flatten a battery over time. Not a problem if you are on Mains Hookup but NOT when on Leisure Battery ONLY.
Goldie
DM
GrumpyGranddad
GrumpyGranddad
Brian’s Dad
Shadrack
