Morsels
Hi, we are in a situation - have Roger’s solar panels fitted on our 6.1 Ocean and the VictronConnect controller says both leisure batteries are fine. But VW control panel thinks they are empty. It tells us to “charge now!” and nothing powered by the batteries is working (fridge, lights). On 240v hookup which we just tried, we couldn’t shift the “charge now!”. So 30 mins or so later we switched to running the engine with the “max charge” button pressed on the touchscreen, but after 45 minutes it still says “0 hours”, still goes to “battery flat, charge now” when we turn off the engine or try again on outlet power.
It is showing voltage as 12.7V but amps going up and down wildly from -18A to +32A over a few seconds, back and forth. I am a bit out of my depth and would love and advice.
How long should we run the engine for to see if the batteries take charge? Or for the control panel decides they have charge?
there a way to “reset” the control panel?
We are on holiday so need to find a fix.
(We have temporarily disconnected the solar to rule out rogue possibilities, but I am at a loss as to what else to try.) Thanks in advance!
