I
ioich
HI, I'm based in Italy and just picked up a Fiamma F45S with the Califormia T5/T6 mounting brackets included (for the LHD version - so mounting on right hand side of van). Much to my dismay the rear bracket doesn't fit 100%. The mounting holes fall to the exterior of the vehicle and the bracket is also too low when mounted plush on the multi-rail. The seller has suggested that my van may have have work done on the roof ( I bought is used last year - build year 2016) - but as far as i can see it looks all normal.
I've been trying to find another California without an awning mounted to test the bracket, but it's proved impossible so far. I have tried the bracket on a T5 with a Thule awning mounted - it wasn't a perfect test, the holes seem more alligned (but this is psobably du to it being positioned more to th rear of the vehicle than the mouonting points) but the part of the bracket that overlaps the 3 holes is still lower than needed. See below -
Here's mine again from a similar angle -
I'd really appreciate it if anyone has has similar issues and found solutions for mounting asside from sending the Fiamma brackets back for replacement!
Thanks!
Thanks!
