Not for the shower as mine is a 2009 without shower, but I have fitted a Truma 5L 300W water heater and it's made the van into a whole different and far more usable beast - with porta poti too, no facilities are required. Truma just goes on the bottom of the left cupboard and still leave shelf space, standard-fit Cali tap has a H/C mixer direct replacement with H and C hoses, power for the heater (and the 13A socket too!) without hook up connected is supplied from a 700W inverter in the side of the right cupboard running via switched ignition relay (engine running) from the main battery and alternator, and with hook up connected, socket and heater are auto switched to be powered from the hook up. On the road the heater is on and you can pull up, wash your hands for 20 seconds whilst singing something appropriate, draw hot water into the 500W mains kettle for a minute or two to boil for tea, have an all-over wash at night so no showers needed, etc. It sounds a lot of work to do, but boy is it worth it.
