I have water pooling in the back right when the roof is up
jaydisc
jaydisc
Australia
T6.1 Beach Tourer 150
On 2023 T6.1, I seem to have water pooling in the back right when the roof is up. There seems to be a rubber grommet there, but I remember hearing warnings about clearing drains. What should I do, please?
Right side (pooling)
Left side (seemingly fine?)
Those on the back are easy. I use a tyrap to clean it. Just push in the flexibel bit and flush it with some extra water. If you open the tail you can see trough the unblocked drain.
On the front the channel is longer with some bends. Loads of info on that.
Assuming you are parked flat and the holes not blocked, it will drain. Water is designed to run to there from the roof when up. If you are nose slightly forward it wont drain fully when parked but will when you drive.
Lift the tailgate, you will see the exit point which looks very similar to the entry point, is it blocked ?
If you do clean it out take care as the drain tube is in 2 parts. That’s 2 tubes with one sliding over the other, with the overlap forming the join/seal. If you are too heavy handed you can end up with them being dislodged …. I did !
Really not much to worry about.
Get a syringe from Amazon and gently squeeze some water through.
I once spent a half term when if it rained outside, it rained inside.
All part of camper life.
Doesn't look like that much water to me. Try to pour a cup of water in the corner and see what happens (fixing a dislodged tube is a bigger problem to solve)
May I ask how you fixed it please? :)
