T
Traveller1977
- Messages
- 66
- Vehicle
- T7 California Ocean 4 Motion
I have just been looking for threads about roof drains and spotted that you had no reply to your post!
In my opinion you should have no leaks into your cabin following rain or at any other time even if the drain holes are blocked.
It occurs to me that maybe someone has tried to clear a blocked front roof drain in the past and in doing so has inadvertently punctured the drain tube (They go 90 degrees from the roof down the "A" post).
If it were me, and you are sure your problem follows a roof repair, I would go and talk to the dealer/body shop who made the repair.
I would be interested to know how you got/get on resolving this matter.
Hi. Well it is an extremely long story, but here's a brief update - Since Nov/Dec 2016 after we noticed the initial roof leaking after the repair, we have only just got our Cali back "for good" (we hope). It has been back and forth since the roof repair was done, probably about 8 times or so.
Numerous discussions with VW on where the leak may be coming from, numerous fix attempts all failing, until they recently resealed the black plastic runners on the top of the van closest to the Windscreen. they believe this is where the leak was coming from.
However I am now so sceptical and lacking confidence that it is 100% resolved, the roof lining is now stained from the leaks so to replace this the whole roof would need replacing AGAIN and all the internal lining is oil stained from the greasy hand marks from the technicians. We have not had use of the Cali all year, only once for 2 weeks when we insisted to have it back (when we knew we wouldn't experience rain on the continent), a vehicle that we all purchase for this purpose of using as a camper van.
The fact that VW technicians initially advised there were no drainage holes; returned the vehicle with leaves/acorns inside the rim/seal with the roof down as well concerns me greatly, I also believe there is no centre out there that is 100% knowledgeable in a vehicle that is not cheap to own or run. I also feel that with all the repairs and tinkering with the vehicle it is now worth less than a vehicle without this "roof corrosion" issue. Happy to hear any thoughts on this.
