D
Doug Curran
Has anyone information whether it is possible to install Lithium batteries in place of AGMs for the leisure positions on a Cali?
I’ve just done it in my T6. You will need a DC-DC charger to replace the split charge relay. On my T6 the AGM profile of the EHU charger is fine with most LiFePO4 batteries. The shunt for the multi-function display still works although the Li batteries will have different voltage so you will lose a bit of accuracy but it’s still a useable guide. Also on EHU the trickle charge to starter battery still functions.Has anyone information whether it is possible to install Lithium batteries in place of AGMs for the leisure positions on a Cali?
How did you connect the DC-DC charger and still have trickle charge to the starter battery on EHU?I’ve just done it in my T6. You will need a DC-DC charger to replace the split charge relay. On my T6 the AGM profile of the EHU charger is fine with most LiFePO4 batteries. The shunt for the multi-function display still works although the Li batteries will have different voltage so you will lose a bit of accuracy but it’s still a useable guide. Also on EHU the trickle charge to starter battery still functions.
I installed 2 Xplorer Polar Max 100ah batteries which has effectively over doubled my useable capacity at less than half the weight. The Polar Max will charge and discharge down to -20°c. which might be important if you’re in Canada! Non heated Li batteries will only safely charge down to 0°c. I had a bit of a juggle to get the battery to fit in the rear, I’d recommend looking at the Titan batteries which are more expensive, slightly higher spec but have a 100ah model that is exactly the same size as the existing AGM batteries making install much easier. You will likely have different options available to you locally. I used a Victron 50a smart DC-DC charger which is both small enough to fit under the front seat with the battery and sheds heat very efficiently.
Budget wise (including additional cabling) batteries and charger it’s between £1-1,500 in UK, I’m guessing similar in USD. It’s doable if you are a competent at DIY with a good understanding of auto electrics if not you will probably need to budget for 6-8 hours labour for install by a competent auto electrician. The trickiest bit is wiring the DC-DC charger to the alternator.
Hope that helps.
I didn’t do the install alone I enlisted the help of an expert! I tightened some bolts, made the tea and did a lot of swearing manoeuvring the new battery in the rear cabinet - VW basically left no wriggle room with the hatch even though there is 20mm or more length and a bit more height space for the battery in the cabinet.How did you connect the DC-DC charger and still have trickle charge to the starter battery on EHU?
A circuit diagram would be very useful to any of us that want to do the same.
