Smalls74
Good evening all,
Sorry to start yet another fridge topic! However I’m struggling to find an answer to my issue.
2012 California SE.
75.000 miles.
Batteries show 12.8v when 100% charged.
I can switch on my fridge and it will sometimes work for a few days without issue. Other times it switches itself off and I get the dreaded flashing snowflake symbol. Fault code 3010 shown in the control panel. This refers to ‘Short circuit input icebox’ “actual temperature”.
If i reset the control panel the fridge starts working again. Sometimes this can be for an hour, sometimes days.
The intermittent fault occurs in all situations, both using the leisure batteries and on EHU, and it doesn’t matter if I’m stationary on on the move.
I popped into Penguin Refrigeration today as I was passsing by. (I don’t live local, but was on a road trip) They had a quick look and said it was possibly the thermostat or control panel. They recommended having a separate thermostat fitted inside the fridge. This would use small amount of space but would bypass the VW unit and the control panel. There be a temperature selector in the fridge that I would use to choose the temp I wanted. They said it would involve drilling a small hole in the fridge to fix the thermostat in place. Or it might be for the wires. I can’t remember exactly why.
I’m a bit dubious about having a separate thermostat inside the fridge but if it works then maybe its the way to go?
I’ve already had the roof converted to a manual one because of the shoddy VW electrics letting me down.
My question is, is there anything straightforward I can have a go at before resorting to having a separate thermostat fitted?
I’m pretty useless at DIY and even worse when it comes to electrics!
Thanks in advance for any help/guidance you can give.
The van is booked in for Friday morning with Penguin so I haven’t got long to decide what to do.
All the best,
Smalls.
2012 California SE.
75.000 miles.
All the best,
Smalls.
