Julesverne2000
I’ve just discovered a leak from the tailgate. May well be the often reported issue with the seal. A bit of a surprise as this is the first time we’ve noticed a leak since getting the van in April (excluding the bellows, obviously!)
I’ve read the advice to lift the seal but would be good to have a bit more info on the procedure.
Is it a horizontal or vertical pull away from the van? Is it immediately obvious if you’ve done it correctly? Are there any signs that it’s not seated properly in the first place?
