Loz
I don't expect the control panel has been updated since VW moved to AGM batteries.This chart doesn’t correspond to my control panel display readout.
They’re sending someone out as I type. I’ve also taken pics and emailed the manager.You need to insulate that terminal! So I expect the 80A fuse at the front is now blown if that terminal has touched ground.
Try resetting the Control Panel.This chart doesn’t correspond to my control panel display readout.
Sorry Alison, I was away at a concert Friday, back today...Their proposal is to fully charge it, and another Cali, have both overnight with heater on and see what the batteries say in the morning on the two Cali’s... so not exactly what I would call a proper drain test...?
Any more advice on how the battery drain test should be conducted would be welcome.
My leisure batteries went completely flat (0%) for a few days at a festival where I could not charge them. They have never been the same since. I can charge them up on a long drive and they immediately drop to 12.2V. Your batteries sound as if they behave like mine. I was told the VW battery test passed but the dealer seemed unconvincing and their technical competency didn’t extend to answering some simple questions about the test.The van went in for the battery replacements on Thursday. I was slightly surprised not to receive any documentation detailing the batteries (as would need receipts, etc. if I sell it). Then I received an email saying the service manager would be sending me a technical email with the results from their tests. This surprised me as I was under the impression they were simply replacing all the batteries.
Decided to wait over the weekend. Drove 90+miles on Friday for agility training and batteries showing 100%. 2 miles Saturday and 100%. Put the heater on level 4 for 10 mins on Sunday to defrost the van and they batteries dropped to 50% (12.2 Volts). So does that mean they didn’t replace the batteries after all?
I’m dumbfounded...
I would say not Alison, I'm afraid, unless you still have a fault somewhere. They should have shown around 80-90%, 12.6 - 12.7V, the lower value if only 1 battery was supplying and the higher value if both were working, based on the heater drawing 15A for 15-20 mins. Did you read the % / V right at the end of the heating? The battery voltage can recover slightly once the load has been removed, say 20 mins later.... Put the heater on level 4 for 10 mins on Sunday to defrost the van and they batteries dropped to 50% (12.2 Volts). So does that mean they didn’t replace the batteries after all?
I’m dumbfounded...
It was definitely 50%, voltage might have been 12.7 - that’s what I made a mental note of but wrote down 12.2V - so I could have noted it incorrectly.I would say not Alison, I'm afraid, unless you still have a fault somewhere. They should have shown around 80-90%, 12.6 - 12.7V, the lower value if only 1 battery was supplying and the higher value if both were working, based on the heater drawing 15A for 15-20 mins. Did you read the % / V right at the end of the heating? The battery voltage can recover slightly once the load has been removed, say 20 mins later...
If I don’t get a good response from them tomorrow I will take a look. I have always kept them charged regularly on hook up and drive a lot. Even when I didn’t drive with back problems last year I regularly had them on hook up and had a neighbour start the engine and leave it running for 15 mins. They were still working fine when I camped in September...Is it possible for you to have a look at the rear battery, by opening the cover? You should see if the battery looks new (clean and possibly see a date marking), of course, your original battery may have been clean too!
The dealer could have had some 'older' new batteries which haven't been kept fully charged, they should be kept above 60% ideally for long life. As @Lightning mentioned above, once they are discharged below 12.4 V and not re-charged for a while, they can permanently loose capacity.
Good tip! I’m still refusing to touch anything whilst under warranty as simply do not trust this dealership.I know its a bit after the fact now, but if I asked the dealer to change my batteries, I would have "marked" them so that I knew the work had been done.
???Sunday eve and just received this reply...
Apologies for the belated reply, I am still awaiting VW to come back to me regarding some questions about the algorithm used by the onboard voltmeter.
The tests carried out on the charging system current draw, on the vehicle showed the following
Stage 1; 0-15 Mins 0.9 -0.11 amps
Stage 2; 15-30 Mins 0.03 amps
Stage 3 30+ mins 0.005 amps
All these readings are within specification.
Charging voltages on these systems run at about 14.3 volts, with a resting battery top of charge voltage of an absolute maximum of 12.8 volts. (Theoretically a battery of this type could show a resting voltage of 13.2 volts, but this would need to be un lab’ conditions) (6 x 2.2volt cells)
I will check with VW as to what the calibration of the on board voltmeter is set to for 12.20 volts. If I was testing a battery personally and saw a reading of 12.20 volts, my view would be a 95% charged battery.
Looking at the spec sheet on the aux heater it will work down to a voltage of 7.7 volts.
If 12.70 volts is 100% charged and 7.70 volts being classed as 0% charged, 50% should be about 10.20 volts, but I will need to verify this with VW.
It could be that we are chasing an issue with the onboard meter rather than any charging issues.
Once VW respond I will be in touch.
Kind Regards
VW Guru has stated in the past that the VW test does use charging current as an acceptance parameter.???
I have no idea what the stage tests are, charging currents? which have no bearing on the battery capacity state. Charging voltage is correct, around 14.3V.
I would say that the voltage range for any AGM battery would be (no load connected);
12.8V 100%
12.6V 75%
12.3V 50%
12.0V 25%
11.8V 0%
I agree that the display isn't particularly accurate.
If the aux heater took the battery down to 7.7V, the battery would very quickly be U/S!
Just my 2 cents and I'd be happy if anyone was to contradict or agree, but I'm sure Clarks man doesn't know his batteries!
80 amp hour batteries.One more question you could ask them if they still refuse to change them is:
How does the remaining capacity of each battery compare with its specification?
I think the VW batteries are specified as 115Amp hours each. So what are they now? This just means that they theoretically should be able to continuously deliver 11.5A for 10hrs or 115A for 1hr for example.
If they cannot tell you what their actual capacity is, then how have they demonstrated that the batteries are ok to your satisfaction?
Thanks, I’ve just ordered a pair. This thread has reminded me how annoying my batteries are.80 amp hour batteries.
these are the exact Varta replacements. The batteries supplied to VW by Varta are black. Those sold by Varta are silver.
LA80 Varta Professional Dual Purpose AGM Leisure Battery 840 080 080
LA80 VARTA Professional Dual Purpose AGM Leisure Battery <i>Innovation with Purpose, Premium Experience, Powerful History</i> VARTA was founded in 1887 Germany, and was established fully in 1904 by delivering the first electric vehicle battery, famously driven by Thomas Edison. Soon after, VARTA...www.tayna.co.uk
