jpmcqAndRory1
I have been reading through some of the older posts regarding leisure batteries and it has helped but looking for confirmation that I have understood it.
I have recently purchased a 2014 T5.1 Bluemotion California beach and originally was intending to just install a Victron bluetooth smart shunt. However, I am now of the opinion that it's probably best to replace the existing leisure battery whilst I'm at it because it's 10 years old and non AGM. I am also thinking that I would like to add a second leisure battery under the passenger seat and an inverter for when not on hook up.
I have checked the starter battery and that is AGM so the voltage should be ok for me to replace the existing leisure battery with an AGM one? No need for a smart alternator?
The advice seems to be to replace with the Varta 80ah AGM battery and assuming that's what I would have under the passenger seat also, I would be limited to 1500kw inverter? You will not be able to use the full 1500kw when using the inverter so I wouldn't be able to use an air fryer that is rated at 1496kw for example?
Lastly, are there any newer AGM batteries, with higher ah, that will fit underneath the seats?
Thanks in advance.
Starter battery
Leisure battery
Thanks in advance.
Starter battery
Leisure battery
