Hobbit's Mum
Hi, have just joined as hubby bought a 2013 Cali Beach last Thursday, though I found this forum about a week before & have already learned a lot!
So, from being a complete novice, I know that the Ocean has an external electrical hook up socket, but the Beach does not. However, it does have a leisure battery and various 12V sockets.
I have 2 questions about this.
Firstly: We want to buy a compressor fridge & charge phones & other electrical devices while we are away, but the manual says "using electric appliances with the engine switched off and the ignition switched on will drain the battery. Therefore only plug electrical consumers into the sockets when the engine is running".
I thought the point of a leisure battery was so you could use devices with the van stationary & engine switched off. I understand that it will drain with use, but isn't that what it's expected to do? Can we really only run electrics when the engine is running?
Secondly: I am thinking that we would only get maybe 24-30 hours use of a fridge unless we did connect to a hook up, and it seems we can buy a connector with an RCD & 3 x 3 pin plug sockets. How do people route the cable into your Cali?
Thanks in advance for any help.
