Z
zend
Hi,
I have recently become a new proud owner of a T4 California Coach 1998.
I have found out that the gel battery (140 AH) inside is now 20 years old and very much dead. So I have purchased a new one (Varta 190ah LDF, which has the same dimensions). Unfortunately, the car won't recognize there is a second battery (the battery symbol on the Westfalia unit keeps blinking). So I started investigating, reading through the forum but couldn't reach a solution.
Some facts:
The battery is new.
I can tell that it is charged as the previous owner installed a USB charger directly on the battery, and they show good voltage when the car is off (12.5) as well as when it is on (14.2).
Based on the voltage, I can confirm that the battery is charging and the relay is functioning.
When the car is off, the heater and the fridge won't work. When on, they both work.
I checked the DIP switches on the westfalia unit and they are correctly off, on (for traction battery) , off, off).
I checked the fuses and all seems all right ( except for the water pump (3A), which is burned), but the pump goes directly into the 12v stocket under the 220v stocket and functions all the time with no problem (car on or off).
I check with voltmeter and the fuse box behind the driver shows 12.5v on the left side so I guess it should be fine as well.
I also checked the westy unit, but could not find any "cold" place that would indicate any problem.
I did try to restart the unit by pulling out the 1st fuse (5A) I believe.
Finally, when I did all the checking with the voltmeter, the unit stopped showing the water level in the fresh water tank. (Actually, previously it was showing fine, then it stopped showing the level, despite having some water in it (around 10l) and and then finally the symbol disappeared). It laso stopped showing the battery voltage while driving (previously, when on, it showed some value, and when off it showed --:--). Now it only shows --:-- all the time.
Could anybody help? Cheers!
Some facts:
The battery is new.
