Low ambient temperature or faulty regulator or blockage/compression of pipe work.There is half full 907 gas cylinder but suddenly the max flame on both kitchen burners has become very low. Anyone have an idea what might be the cause?
Thank you.
Should be a Warranty exchange possibly.Checked all taps, WG. Ambient temperature c.15deg so faulty regulator or blockage in pipework? Gas flows freely out of tap on top of canister, and the fact that both burners affected rules out, to my mind, any issues post red tap under sink (?). Here’s hoping it’s the regulator. Thanks for your help WG.
You could do the Calor Regulator Conversion.Definitely the regulator. Kind soul next to me at Slimbridge took off his for me to try. Bingo, worked a treat. Will now be getting a new one. As you say WG, unusual for regulators to fault.
This is a good idea but thought I’d try the VW warranty route.You could do the Calor Regulator Conversion.
If you can tie your shoelaces you can do this.
Makes getting the bottle out easy as well as tightening the regulator without overtightening, and no more possibility of jamming the screw lid because the God regulator/tap is not correctly positioned. Pictures and parts in thread below.
Loose gas connection
Hi I had a situation at the weekend when I checked and turned on the gas when on the camp site (everything working well) thenther next day drove up the road with gas tap still open (yes I know this is not best advised) and the connection between the regulator and tap had come loose and gas was...vwcaliforniaclub.com
that was me. did you get a new un?Definitely the regulator. Kind soul next to me at Slimbridge took off his for me to try. Bingo, worked a treat. Will now be getting a new one. As you say WG, unusual for regulators to fault.
No problem, and you are probably better off doing it yourself. You can probably get it from the Forum shop cheaper using your VIP discount. If you can't find it on the shop site then give them a ring.I have a problem with the gas not coming through (it has been sporadic for a few months now) and looking at all of the posts on here it may be the regulator. Have spoken to VW dealership and there seems to be an issue about fitting a new regulator as they don't have any gas qualified people. Is there any issue fitting it yourself and if you do does it invalidate any VW warranty?
