Midgie-proofing the roof vents
Hello
Did you ever manage to obtain a solution to this midge problem. I’ve very keen to find one too.
Small pack of Midge net from https://www.totallyherby.com/
Fabric glue from Amazon
Cut net to size and stick in place on the small vents in the popup tent.
If you want removable, then use magnets.
As you are in Edinburgh, and may go more often to the Highlands, also consider midge proofing the VW mosquito nets.
Get the large pack of midge net from
Cut to size
Use glue gun to glue to mosquito net.
... Simples. :thumb
Cut to size
... Simples. :thumb
The VW window screens are easy, a butter knife and a square of midge net.
Work round prising the two parts of plastic apart and sliding the net in.
They have been great but staying somewhere near the coast or high so there's a breeze / strong sun is easier.
What ever you do some will find a way in, on clothes etc so an evening killing session can be satisfying and talking antihistamines helps the itch if you do get bitten.
Thank you for that tip. Was too scared to pry them apart.
I did similar to what sbmcd described above, for the small vents. Fibreglass netting sewn onto the tape around the vent, using a curved upholstery needle. A bit laborious but happy with the result.
Sit up top, get a curved needle and sew midge mesh over the vents, not easy but it works.
Thank you for the replies. Has anyone tried spraying the net with Permethrin? I imagine that midges would still get through?
For those who’ve pried open the VW window screens, I’ve had a brief go on one, but seemed to do damage to the existing mesh.
Is the idea to totally separate the 2 plastic parts and refill the void with midge net like a sandwich? Or separate enough to add midge net on top of existing mesh?
Don’t really want to knacker the screen by overdoing it.
TIA
All one needs is a square meter (can be smaller) of midge netting (per window, net curtain material works) and a good selection of strong magnets. Stick a small thin patch of felt to the base of the magnets to prevent scratching the van.
TIA
I cut the fly mesh out with a knife then pried the plastic apart enough to push in the midge net with a blunt edge. Repeat. I taped the corner holes also.
Also, practice getting the screen in efficiently, so as not to let in hordes of midge in. If theres loads on the screen, i often drive off slowly to blow the midge off, then stop and quickly take the screen out.
I've just done mine.
Get a tea light lantern from IKEA and buy some citronella tea lights, light one each morning and night in the roof and all the midges vacate or DIE!
