Chris Ratay
Overlanding South America w T6.1 Ocean 204, 4M+
Automatic Regeneration on my 2023 VW T6.1 in South America.
After a high altitude clog in Ecuador, I started to monitor the DPF soot levels.
I found that the VW Regen automatically kicks in when the soot reaches 30g, and burns it down to about 8.5g. Driving in the Andes, it reaches 30g every 150-180km, and at sea level it's closer to 225km cycles. With more than 35,000km driven, the van has done over 1500 auto regenerations, the majority of which I never knew were happening. If you ever smell a slight burning odor - it's happening!
The Regen itself takes anywhere from ~10-25 minutes, depending on driving conditions. Downhill or stop-and-go traffic takes about 25 minutes, while foot on the gas is closer to 10 minutes.
I've driven to nearly 5,000m in altitude, but it wasn't during a Regen. After many attempts I have confirmed the ECU doesn't allow the Auto Regenerations to kick in above 3,300m. If driving above that, I estimate I have about 50km to get lower before the soot reaches 35g and the DPF Warning Light comes on.
According to the dealer computer in Ecuador, I got to 42g before going into limp mode. (You can still drive in limp mode, but "they say" anything above 50g can only be cleaned manually.)
Since the Euro6 van is made for Europe/Australia, the 3300m attitude threshold isn't a big deal.
Fortunately after going into limp mode, the dealer's computer was able to clean it with a Forced Regen. Be sure to change the engine oil if the vehicle is not moving during the regeneration.
After the limp mode fiasco, I started monitoring my DPF using the $6 paid version of the VAG DPF app with a basic OBDII reader. My data and assumptions above are from monitoring dozens of regenerations over several months in South America.
These days I assume I can drive the T6.1 above 3300m in altitude a total of 225km between regenerations, maybe 250km if I'm lucky. This means Bolivia is not an option.
The VW recommendation to "drive at 2200-2500rpms @80kph for 25 minutes" has never initiated a Regen when I've tried. I've experienced Regens while at stop lights during rush hour traffic, so those instructions don't help me.
Here are a few screen shots to show the auto Regen in process:
1 Current soot level
2 Regen Duration (basically a timer)
3 Distance since last Regen
4 Time since last Regen
5 Oil Ash Residue - this slowly accumulates. When it gets to about 120g I'll need to have it cleaned out. With 35,000km and >15g currently on my van, it'll be a few years.
6 DPF Input/Output Temperatures - normal driving temp is 225-325C, but increases to 500-625C during the Regen process
7 Current time
8 Visual scale. When the Regen cycle finishes, it only goes down to ~28%
7 Current time
