Aidy P
Don't play that 'What If?' game, you'll never win!
- Messages
- 1,035
- Vehicle
- T6 Ocean 204 4Motion
99% certain faulty ABS sensor. Commonly a rear one but need a code reader to identify.Has anyone else had this combination of error warnings…
- Error - Start Stop
- Tyre Pressure Loss Indicator Currently Not Available
- Error: ABS / stabilisation control (ESC)
Lights on dash as photo.
Van driving ok.
You might well get some symptoms if it is intermittent, from the 4Motion. I did.Thanks. I thought probably a sensor as the van drives fine and there hadn’t been any obvious incidents on the road to cause damage. I had covered a lot of miles so the debris suggestion could be relevant.
It has been intermittent. Anything I can do to clear this at home @WelshGas ? ThanksYou might well get some symptoms if it is intermittent, from the 4Motion. I did.
Mine was intermittent then became permenant. During the intermittent phase there were occasions where pulling away seemed as if the brakes were on. I believe this was due either to the ABS or Haldex responding to an abnormal sensor output. Once the lights were on permanently the drive was fine.It has been intermittent. Anything I can do to clear this at home @WelshGas ? Thanks
Thanks for the info. I’ll get it booked in to the garage.Mine was intermittent then became permenant. During the intermittent phase there were occasions where pulling away seemed as if the brakes were on. I believe this was due either to the ABS or Haldex responding to an abnormal sensor output. Once the lights were on permanently the drive was fine.
Carista showed N/S rear sensor. I checked for any debris, the wiring harness - all fine.
When in for its service VW were unable to confirm the diagnosis as their computer system requires a connection to a VW mainframe. Anyway I told them to replace both rear ABS sensors, although Carista said only one was faulty. Contrary to others who have said it’s a simple 5 minute job, both sensors were well and truely immovable and basically had to be removed piecemeal. Took a few hours by my garage. I changed both as it seem when 1 rear fails the other soon will and I’m off to Norway in 5 weeks.
Mines not a true comparison, it took 3 hrs to get both out whereas it should be literally a 30 minute job as the sensor is unplugged, locking bolt removed, sensor out , new one in, locking bolt and plug in. Obviously the vehicle is jacked up and wheel removed and replaced.@WelshGas. Back from the garage. ABS sensor as you predicted. Waiting for a quote. How much did you get charged please?
Not simple if the sensors are corroded in. Quit an involved job actually to carefully remove the sensor piecemeal and avoid damage to the hub.Quite a simple job to do yourself, pattern sensors available for around £15-£20 each, Takes about an hour a wheel, if you clean everything as you go, good opportunity to service brakes at same time
And that shows your lack of knowledge regarding changing these sensors that don’t just pop out.Sensors are plastic casing around a hall effect resistor, hub is metal, corrosion isn't a problem just use a heat gun
Oh My apologies...How many have you actually changed...what lack of knowledge do you perceive.And that shows your lack of knowledge regarding changing these sensors that don’t just pop out.
Like I said above. True, corrosion doesn’t affect the sensor per se. I’ve done a few, some easy some very definitely not, and not everyone has your obviously superior knowledge or capabilities.Oh My apologies...How many have you actually changed...what lack of knowledge do you perceive.
If they are broken, you break them off, drill a small hole, use an "easy out" to loosen them and apply a gentle heat to break the studlock glue VW like using and then gently tease them out with long nose pliers, hence the 1 hour per wheel. If you are stupid enough to pay your professional for more than an hours labour that is your choice! Metal corrosion does not affect plastic sensors. If they "pop out" then all four can be changed in an hour. That is my Lack of Experience.
If you are enjoying life why are you so Grumpy?Like I said above. True, corrosion doesn’t affect the sensor per se. I’ve done a few, some easy some very definitely not, and not everyone has your obviously superior knowledge or capabilities.
