JohnGuppy
After the fitting of the solar panel yesterday I am now running on 100% solar, after setting the fridge to mid range , at 8am today I checked the state of charge and its not charging !!! normal folk would think this don't work ?
Both leisure batteries reading 14.19volts fully charged
Solar panel output 66w at 16.8volts
Charge float means trickle charge
load 2.4 amps being drawn by van
If I elevate the roof later it will give a more correct angle towards the sun and this will produce more output so it is worth considering site location to get free power
On my house I have 8 solar panels of 1200 w charging 4 off 400 amp hr lithium Phosphate batteries ( can charge and discharge from full to 20% ) this runs my whole house for 12-16 hours free
Also you do not need the sun to be out light will produce some output
I will check in a weeks time and see how things are going
