Hubble
- Messages
- 69
- Vehicle
- T4 PopTop
Hi
I bought a 2003 westfalia california pop top about 3 weeks ago and soon discovered the mains charger was fried. I got a replacement multi stage charger from Caravan & Leisure Technology (caravantechnology.com) fitted by a local auto electrician.
Before the charger was fitted the control panel was showing the leisure battery at 70% charged (from driving around). The charger was fitted and the electrician tested the voltage when hooked up - 14.6v or something like that. There is an external control/display now mounted inside the cupboard.
With the van on hook up at home the charger display is showing that the battery is now full but curiously the overhead display in the cab is only showing 70%.
I phoned the electrician and was told
a) gel specific chargers only charge to 70-80% of the capacity that chargers designed for lead-acid do.
b) in order to allow for surges created by regenerative braking modern batteries are generally kept at less than maximum charge to allow some headroom.
There may be some truth to explanation a), but regenerative braking in a vehicle with a leisure battery? Sounds unlikely.
Anyway, has anyone had similar experience with a replacement charger?
