Hi Matt, I’ve checked that and padded out any noise coming from it..Could it be the table in the door?
Thanks HC,Check door , rails and rollers .
Unwind awning , check rubber pads in the housing , wind back in ....
Check table in sliding door (you done that)
Make sure the noise is not comming from something whole diffrent , someone sitting in the rear while driving can hear diffrent things than when you are behind the steeringwheel driving.
Thanks HC,
I haven't checked the rails and rollers yet but have gone through everything else that you've mentioned. I hadn't really thought about the rollers as I had assumed that there wasn't any scope for adjustment. Aren't they just bolted to the door? Presumably the rails are a fixed elements of the chassis? I will have to take a closer look when I get some time and get aquainted with how it all works.
Thanks Jabberwocky, not thought of this so will investigate in the morning.The awning? I had this problem and was certain it was the door but eventually tracked it down to some misplaced rubber pads inside the awning case..........just above the door!! Worth a look if not done so already.
Hi Andy, mine sounds exactly the same. I’ve had it from new (Dec 2016) and this noise only developed a few months ago, so suggests something has worked loose. It’s very annoying..Hello Veedlescnapper
We have the same thing in our 2013 T5 SE.
The noise is definetly coming from the sliding door when it is closed. The noise is a creaking and not a rattle/bang and is normally only at low speed (as though something has not been tightened properly).
We have ruled out the awning, both tables, seats and other possible causes.
I have removed and lubed the B pillar collars as well as checking the runners all of which appear correct.
With everything else removed from the van and one of us sat in the back the noise appears to be coming from the inside of the sliding door close to the handle/lock .
My next step is to strip the sliding door to find the noise. .
Does anyone know of any instructions for the Cali sliding door??
Andy
Something else to consider - the Awning casing itself. Where the two parts of the awning case come together when closing (See Photo). We found this a source of a rattle and put a thin cut strip of self adhesive velcro (loop side only) on the moving case part only. Silence!I also have had an intermittent rattle coming from what seems like the off side B post. It sounds like the source is located in the area near the upper drivers seat belt fixing.
Initially, I thought it was caused by the arms in the awning casing rattling or possibly the same but due to the rubber cushion pads having come off. However, regardless of numerous adjustments to the awning mechanism and re-sticking the rubber cushion pads, the noise persists. I am now inclined to think that the culprit maybe the top sliding door locating fitting. Unfortunately I haven't yet had the time to investigate.
The suspect upper sliding door location fitting can be seen on the B post in the top right of this photograph:
Questions:
1. Has anyone else had a similar rattle?
2. Was it caused by this upper sliding door location fixing?
3. Did adjustment cure the rattle?
Many thanks,
Paul
You may be onto something there Rik,Something else to consider - the Awning casing itself. Where the two parts of the awning case come together when closing (See Photo). We found this a source of a rattle and put a thin cut strip of self adhesive velcro (loop side only) on the moving case part only. Silence!View attachment 28947
Tomorrow I am also going to try closing the sliding door on our Cali with a wad of tissue paper jammed in the upper sliding door location fitting on the B post sliding door jam.I´ve got the rattle, only when on a rough road.
I´m riding awning-less over winter and the rattle is
still there.
So it´s not the awning on mine.
Your observation of there being some slack at the front of the cassette when the rear was closed tightly was my motivation to explore this as the potential elusive rattle. I wish for good results for you. Mine is still very quiet!! RikYou may be onto something there Rick,
Our awning was a dealer fitted OE Thule awning. The same dealer hadn't specified an awning when they ordered it as their demo Beach. We had them fit it when we first bought the van, still unregistered. It probably wasn't fitted to the same exacting standards as it would have been in the factory as I have since had to make several adjustments to the fit. Anyway, I have noticed that when the rear of the cassette is closed tighly there is still a tiny bit of slack at the front. Unfortunately, as far as I can see, there doesn't appear to any means of adjusting (winding in at the front slightly), the fabric awning on the reel. I will try your idea as it might just be the answer.
Many thanks,
Paul
I sat in the back of my van this weekend when my son was driving, I was surprised at the amount and variety of rattles when on normal urban roads. The ride there appears to be subjectively firmer than in the front seats. I will be securing the shelves in the rear cupboard and fitting a thin pad on the awning side panel as noted above and see if that helps.Your observation of there being some slack at the front of the cassette when the rear was closed tightly was my motivation to explore this as the potential elusive rattle. I wish for good results for you. Mine is still very quiet!! Rik
Thanks for the advice,
