noisy valve advise please before mon !
R
ROB
hi,
van just had small service, they said i had a noisy valve would cost £154 to replace
for last 9 months or more there is a fart like noise when turned engine off is this the noisy valve?
next question is should i get it done asap now i know is it causing a problem or will it ?
can anyone help with what the valve does? thank you all
Is this the "moo" valve?
Are you out of warranty?
Sent from my GT-I9505 using Tapatalk 2
I think its called the n75 valve quite common to go on a t5 about £40 for the valve not sure how hard it is to fit or if it will cause any problems if left
moo valve ? it does sound like a moo now i think of it
2008 cali, so no warranty , is it a common problem ? cheers
will book in to replace valve on mon,
not done 30k & already had starter motor too
Had ours done under warranty a few weeks ago after it started farting/mooing when we were in France. Apparently it's something to do with the turbo and if it fails completely then you lose the turbo according to the dealer. He knew immediately what it was when I described it so I assume it's fairly common.
thanks, booked in but not for 2 weeks & some big journeys first so hope will be ok !
