Thanks for the replies folks. For background, we have travelled within Australia for many years in what might be called an expedition-style camper based on a Toyota Land Cruiser 4wd vehicle, including long-distance remote-area travel (eg Simpson Desert, Anne Beadell "Highway"). That vehicle is equipped with a Webasto heater for the camper, 100Ah lithium in the camper, kitchen and water tanks etc, and a 200w solar blanket. Age and health issues are pushing us to switch to a more sedate travelling mode and hence the T6.1 California, with better fuel economy, easier access, driving comfort, more compact, and easier to park in a motel carpark. The camping options are essential for times when we can't get motel accommodation at short notice (an increasing problem here at the moment with motels often booked out months ahead). At times we will have access to mains power, but often not.
I do have a Victron 15-amp mains charger I can use to charge up the batteries overnight when we have access to mains power. We would rarely stay more than 2 days in one location, so I don’t see the need for solar (but may reconsider if our travelling pattern changes). My experience with lithium batteries shows me that cold weather charging performance can be a concern when the batteries refuse to accept a charge below 5 degrees Celsius, but that a 30-amp or 50-amp DC-DC charger can make up the charge fairly quickly when driving, and I expect that having the battery within the cabin of the vehicle may keep the battery warm enough that this isn’t a significant problem. It’s rare (and very expensive) to find a lithium battery locally that has the built-in self-heating capability. We live in a cold part of Australia with regular overnight temperatures down around minus 5 in winter.
My main concern with the Cali will be the capacity and reliable charging of the leisure battery to support overnight camping for two nights, with a fridge, lighting and the diesel heater. Perhaps the available 35Ah from the AGM leisure battery will be sufficient. If not, I can either double up with another 75Ah AGM in parallel or switch to a 100Ah lithium. I’m reading here that many owners have problems with their leisure battery maintaining a useful charge. Perhaps using the “Max Charge” feature will be sufficient. If not, I’ll install a reliable DC-DC charger. From past experience with my other vehicle that will work as I want it to, as long as the leisure battery is isolated from the starter battery.
Thus, my question in the first post above, about whether the “non-isolating” charger will isolate the leisure batter from the starter battery when the engine is off. Modern VW electrics sound a lot more complex and devious than the systems I have worked with up to now!
Thanks again, and a pic of my “other camper” to share.
