I
icic
Yes that might be the simplest solution .. I will have a lookI reckon you could pull the wires off the back of the switch on the cupboard? Don't have that pesky light myself so cant check
Mind you it goes on and off with any input from the switch, so it might not solve the issue, then I won’t be able to switch it off when it does randomly come on. So I might look to do it at the fuse levelI reckon you could pull the wires off the back of the switch on the cupboard? Don't have that pesky light myself so cant check
The issue is that the light is on two circuits one wired into the leisure batteries the also the main cabin door opening lights (engine battery I would think)
