Oil change needed? 2013 SE180
wessexcamper
wessexcamper
hampshire
N/A
Hi All
We bought our 2013 California SE 180 DSG a little over a year ago, from a well known camper van dealer on the south coast. It had done very few miles - just over 10,000. There were no stamps in the service book apart from one where the dealer who sold the van to us had it serviced at a local (non-VW) garage.
This service was in Feb 2017, with just over 10,000 miles on the clock. The service was quite basic but the box showing that the oil was changed with long life oil had been ticked.
Fast forward to now. The van has done 13.5k miles, so 3500 miles and about 15 months since it was serviced. The van tells us that it wants an oil change now (63 days ago) or in 8900 miles.
I spoke to the guy who did the service and he assured me that he would have used the correct long life oil and reset the computer correctly - but that the service intervals are programmed at the factory and it might be on a 12 month service interval. I thought to get the oil changed anyway, but the local (non-VW) garage I spoke to wanted £190 to do it. So I called the two nearest VW commercial centres to see what they think. Interestingly, neither of them asked for the reg number to check on what service might be due (which is the first thing the BMW garages do when you call them). One quoted £198 and the other quoted £222.
I explained the background (as above) and questioned why, considering the van is on a 20,000 mile / 2 year service interval, it should be flagging up an oil change after 3500 miles and 11 months. Both of them more-or-less said the same thing. They said that the oil quality sensor in the sump would be detecting that an oil change is needed due to bad oil quality I asked if that implied that the previous oil change had used a poor grade of oil and they said no, that it would be because the oil had degraded since it was changed. They tried to give me a lot of talk about EGR valves, exhaust particulates, carbon content of oil, viscosity etc. and talked about vehicles without a lot of use not reaching adequate working temperatures and so on. One of them suggested that if we were not going to use the van more, we should consider changing from a 2 year service interval to one year.
Now I try to be open minded, recognising that I am not an expert here. Nevertheless, I fail to understand why a van which has done just 3500 miles needs its (long-life) oil changed after 11 months. I can't see why, had we done another 10,000 miles, the oil would still be good for a further 6500 miles or 9 months. This is not a daily runabout. The shortest journeys it does are well over 30 miles / 1/2 hour and typically a hundred miles or more. Maybe it is that the long-life oil deteriorates while sitting in the sump over the winter, not being warmed up every now and then?
The chap who did the service in Feb 2017 thinks it is perfectly Ok and offered to reset the computer again for free. We may take him up on this. However, we don't feel comfortable driving around in a vehicle which tells us it should have been serviced 2 months ago. Interestingly, the van says that it needs an inspection exactly 2 years to the day after the service in Feb 2017 and about 25000 miles on from then, which suggests that the on-board service computer was correctly re-programmed at the time.
Any thoughts about what we should do (ignore the service request or get the oil changed)?
Thank you!
Personally, I'd say get it serviced, preferably VW, if for nothing else to hold the value of any potential resale...
Just looking at the mileage it has done on average 52 mies per week. I would recommend you have it serviced and use it more often.
These long service periods are aimed at the large volume contract and business buyers. By extending the service period to 2 years/20k miles, the manufacturers are saving companies money and increasing their own sales. The vehicles will be moved on after 2 years saving the cost of lots of services on the fleet.
If you rumble round the internet you will find that many knowledgeable folk state that oil starts to deteriorate after around 7k miles, so a change of oil at 10k mile is appropriate. The sump quality sensor is confirming this. The comments about particulates contaminates is probably appropriate give diesel engine oil goes black very quickly
This is not a full service which will cover many other things, such as brake pads and discs, all the filters, including fuel and pollen and a general check of the vehicle condition.
My advise is get the oil changed as this will be very much cheaper than a new engine should the worst occur. But as your van is out of warranty there is no need to go to a VW dealer, a VW specialist would be just as good and probably cheaper, but do get the service book stamped.
Alan
Even if it was still in warranty you're not obliged to use a VW dealership for basic servicing (that particular monopoly scam was ended some years back).
In any case I've always used independents for servicing on all our cars. Chances are your local VW specialist learnt their trade at the franchised dealership up the road and then went independent at the point when they actually knew what they were doing!
Of course the independent can't undertake warranty repairs, but if they find something wrong you can always then take it up the road to the franchise to get that fixed.
I know, pros and cons, but just saying... ;)
I love my Cali.
I love the thought of his beating heart being washed with only the very best oil in the very best condition.
I do not want him to have a heart attack because I skimped on the oil.
I would have an oil change,
Hi All
Thank you!
The VW garages were perfectly correct. The LongLife oil needs to be used to last 20,000 miles or so. You are Not doing this.
If you read the Handbook and research on the WWW then you should be changing the oil and filter annually with the milage you are doing.
If you are querying the cost for an Oil Change now, then I suggest you start saving for the following,
DSG Oil and filter change at 60,000 miles or 4 years. Sounds as if it is overdue.
The inevitable EGR valve change due to low milage, expensive on the 180.
DPF problems/replacement resulting from low milage use.
AirCon problems. Should be serviced every 2 years no matter what the milage and used frequently.
New set of tyres as they deteriorate over time. 5 years old, never mind the milage, means a grater risk of blowouts.
Brake Discs deteriorate if not used and will need replacing much earlier than expected + Pads.
Thanks everyone for your valued thoughts and opinions, we feel better about getting it serviced now. Lots of plans to boost the mileage over the coming months!
  • Agree
Reactions: Sad
Hi All, well our cali has had its small service incluing the oil change, brake fluid and air con done as well. We went to a VW Van Dealership in Hampshire. Annoyingy, they forgot to reset the computer to show the oil change had been done - we got them to do this before we left the dealership. Computer now shows a service interval of 365 days, which should be 2 years, but they tell me that after a couple of months of driving, based on low mileage it should reset itself "to the nearest 700" ie 2 years. Can anyone tell me if this is true? I was told to leave it for a couple of months and come back to them if still a problem, but there is a niggling doubt that in resetting the computer (for the oil change), they put it on a one year interval programme. Thoughts always appreciated.
To clarify before the service: computer showed oil change -69 days and inspection 272 days. Now shows inspection 365 days after being reset by VW staff today (who needed to be reminded as he forgot).
Did they use longlife oil as well?
